class Date_DeltaRussian { var $intervals = array( "seconds" => array("секунду", "секунды", "секунд"), "minutes" => array("минуту", "минуты", "минут"), "hours" => array("час", "часа", "часов"), "mday" => array("день", "дня", "дней"), "mon" => array("месяц", "месяца", "месяцев"), "year" => array("год", "года", "лет") ); var $from = "seconds"; // Creates new object. // If $from is specified, "granularity" while spelling is $from. function Date_DeltaRussian($from = "seconds") { $this->from = $from; } // returns the associative array with date deltas. function getDelta($first, $last) { if ($last < $first) return false; // Solve H:M:S part. $hms = ($last - $first) % (3600 * 24); $delta['seconds'] = $hms % 60; $delta['minutes'] = floor($hms/60) % 60; $delta['hours'] = floor($hms/3600) % 60; // Now work only with date, delta time = 0. $last -= $hms; $f = getdate($first); $l = getdate($last); // the same daytime as $first! $dYear = $dMon = $dDay = 0; // Delta day. Is negative, month overlapping. $dDay += $l['mday'] - $f['mday']; if ($dDay < 0) { $monlen = Date_DeltaRussian::monthLength(date("Y", $first), date("m", $first)); $dDay += $monlen; $dMon--; } $delta['mday'] = $dDay; // Delta month. If negative, year overlapping. $dMon += $l['mon'] - $f['mon']; if ($dMon < 0) { $dMon += 12; $dYear --; } $delta['mon'] = $dMon; // Delta year. $dYear += $l['year'] - $f['year']; $delta['year'] = $dYear; return $delta; } // Makes the spellable phrase. function spellDelta($first, $last) { // Solve data delta. $delta = $this->getDelta($first, $last); if (!$delta) return false; // Make spellable phrase. $parts = array(); foreach (array_reverse($delta) as $k=>$n) { if (!$n) continue; $parts[] = Date_DeltaRussian::declension($n, $this->intervals[$k]); if ($this->from && $k == $this->from) break; } return join(" ", $parts); } // Returns the length (in days) of the specified month. function monthLength($year, $mon) { $l = 28; while (checkdate($mon, $l+1, $year)) $l++; return $l; } // Функция предназначена для вывода численных результатов с учетом // склонения слов, например: "1 ответ", "2 ответа", "13 ответов" и т.д. // $int — целое число. // $expressions — массив, например: array("ответ", "ответа", "ответов") function declension($int, $expressions) { settype($int, "integer"); $count = $int % 100; if ($count >= 5 && $count <= 20) { $result = $int." ".$expressions['2']; } else { $count = $count % 10; if ($count == 1) { $result = $int." ".$expressions['0']; } elseif ($count >= 2 && $count <= 4) { $result = $int." ".$expressions['1']; } else { $result = $int." ".$expressions['2']; } } return $result; } } ?>
Critical Error!
